Ok, i'm so foolish, i bought 4x1tb drives to run in raid5 on my ICH8R.. but that has a 2TB limit
so i go... ah thats ok... you can run raid5 on XP... im sure you can with vista... wrong...
so now im left with the idea of either a raid10 (doesnt sit well having a 1.8tb volume for 4x1tb drives) or Spanning a 3.75TB volume or Striping a 3.75TB volume...
my question is if i lose 1 drive from a SPAN volume am i going to be able to recover the data from the other 3 drives??? assuming i keep the drive defraged??? or should i just go with a STRIPE volume and gain a performance boost i dont really need??
unless somebody has a solution to get software raid5 running in vista.... that'd be heaps better.
i cant go for a hardware raid card as all my PCIe lanes are used (16x/16x slot 8800GTX and the 16x/4x slot with my areca arc-1220 running 8x400GB raid5)
yeah thanks anyone that helps...
i meticulously backup my data all the time.. so the recovery isnt data critical, moreso its quicker to recover off a hdd than off hundreds of DVDR
