I apologize if this is a repost, but I have done quite a bit of searching both on forums and google and I cannot seem to track down the specifications of the default Lian Li 120mm fans. From what I've been able to gather, they're made by Adda, but Adda make quite a few different models of 120mm fans and their website is less than stellar when it comes to specifics of noise and airflow of each.
Specifically, I'm looking at the Lian Li A05B, but I think it's safe to assume that all of Lian Li's 120mm fans are the same type since they likely get a bulk discount from the manufacturer. Can anyone check the specs on their 120mm Lian Li fans and let me know what they are? I'm wondering if it would be worth it to spend some extra cash on quieter fans if the noise and airflow on the Lian Li fans are less than spectacular.
Thanks much.
Thanks much.
