Quick question, i know this case is rather popular for watercooling, for those of you that chose to mount the rad up front in the drive bays what did you use to secure it?
works great... a 120mm fan will take up 3 drive bays tho. that turned out to be a problem w/ my 3 fan rad
they make a bracket that holds a 120mm fan in the drive bays.... scythe i believe makes it (may/probably am wrong about this). you could probably work with that. use your imagination
