faugusztin
- Mar 9, 2008
Hi,
i have a hard time deciding what to do with my hard drives. Currently i have 5 drives in RAID5 (+2 out of RAID) in my main PC, but the problem is that all those drives make some noise even in a such high quality case like my PC-V1110A.
I'm considering how to make it better in terms of noise and these are the alternatives i came up with :
If you think the last option is the best, what do you think about this setup ? Which case would you choose ? Or do you think there are better choices in both terms of temps and noise ?
P5N7A-VM, E5200, Enermax PRO82-385 + 5xWD6400AAKS at Linux software RAID5.
With P180 mini price is around 355-365. With Antec P182 price is around 390-400.
I'm open to suggestions but bear in mind that some stuff is not present at European or local Slovak market. Buying from USA is not a option, postage fees kills it.
- leaving the situation as is right now. That means 6xWD6400AAKS + 1x WD1001FALS in my main PC.
- moving 4 drives to the HTPC. The problem - HTPC already contains a WD10EADS and the Antec Fusion Remote Max is limited to 4 drives, so no RAID5 from 5 drives.
- selling five WD6400AAKS drives and buying 2 or 3 WD10EADS or WD1001FALS drives, then moving them either to the HTPC (WD10EADS) or to main PC (both type of drives).
- buying some NAS box for 4 drives at least, probably the FSC Scaleo Home Server with 1 HDD, which i would immediately sell after buy - 468 at cheapest store here in Slovakia.
- building a new PC, just to use it as a network storage.
