bignasty said:ok my .02 do you guys realize saying that home built machines arent good for servers is an all out lie??? look at the servers that hardocp and the hardforums sit on, and has anyone checked out rackspace...
jaqie said:I agree about the webhost, scratch that idea. I also talked with a friend and decided that if I have anything to say about it we will be contracting him out for setup(freeBSD part I can do the rest) and consulting. He and I have already talked at length about it and thus the setup I have in mind has changed radically. Ill be editing the original post in a bit to reflect the new setup.
information was already in the thread, guys.jaqie said:after more consideration I am thinking of this UPS solution.
APC Smart-UPS XL 3000VA RM 3U 120V
Part Number: SU3000RMXL3U
Estimated Resale Price*: $1,425.00
APC Smart-UPS 48V RM 3U External Battery Pack
Part Number: SU48R3XLBP
Estimated Resale Price*: $679.00
should provide at least 15 minutes full cabinet runtime, and a lot less expensive then 10k.
I want to config the game servers to shut down immediately upon a switch to battery, that should extend runtime quite a bit.
jaqie said:information was already in the thread, guys.
thanks a lot for the advice. and oh yeah you misread it about how Im configuring the T1 coming in. it IS on a PCI-X card.
dave_graham said:btw, just to follow-up a bit more:
there's no real disadvantage of going the Newisys/Celestica route either. I do pre-configured servers using their barebones stuff all the time and frankly, it's rather damn good....and not too expensive to boot...
beyond that, they're normally validated for all the Opteron families within weeks of release, versus, the months it takes for HP, et al. to go through the process.
cheers,
dave
dave_graham said:i second the opinion regarding the Cisco PIX and Catalyst switches...With lower grade hardware, you always run the risk of problems.
If you need Cisco hardware, i'm more than happy to help....remember also, Cisco does not transfer warraties on software if you purchase the routers/firewalls second hand. you have to buy it new in order to get the full warranty. Also, their support packs are top-notch and would be worth purchasing along with the router.
cheers,
dave
Its not for bandwidth, its for security.Cheech said:The first thing that comes to mind is why have 3 different subnets? I agree that the gamers will suck up some bandwidth, but I don't see the thin clients and WiFi hotspot sucking up so much that they deserve to have their own subnets.
you can actually do that with some of the better D link and netgear switches. I am considering running a layer 2 switch for these but frankly I dont see it as much of a problem... I mean when the bandwidth will really be used is when there is a LAN party... and Ill be limiting the segment they are on via the router anyways...Secondly, about the switches. Granted, I know you need to watch your cash flow, but there is a REASON why these switches are designed like they are. You can manage your bandwidth utilization SO much better with one of these than a switch you can pick up at CompUSA that it's not even funny. Take a class in Cisco if you don't know how to set these up, but I would seriously consider them when you have enough capital to afford them.
you misread me. it's actually coming in on one of the dual PCI-X NICs.Also, I don't understand why you have the T1 coming in on a PCI card, yet everything else coming in PCI-X. It's reasonable to assume that most of your bandwidth traffic is going right out of the building, so why have that possible bottleneck? I know you are using gigabit, but the outside traffic is still coming in on a 33MHz bus port.
no, I know I wont. however, the features in my current DI-614+ are quite impressive for a low dollar SOHO use. site filtering, and the like. I plan on using them as a temp thing only as I put the server back together when it fails. few days wont hurt.The router. I have accepted the fact that you are dead set on FreeBSD, but the whole point of the router is to make routing rules, policies, and so forth. If you have a failover to some 40 dollar router, do you really think you will have that functionality?
ick. nothing but APC. no way im going with anything else. I was thinking (and this was earlier in the thread) of this:What did you come up with as far as a UPS goes? Perhaps something like this: http://www.cdw.com/shop/products/default.aspx?EDC=073732
yeah, you canCheech said:Can a brother get a 515 PIX for cheap?
rosco said:I would also recommend using Dell or HP for your servers. I would definately recommend trying to resell as opposed to selling your own whitebox brand.
I also think you should get a better ide raid card for your router. You said you're going to be configuring the freebsd router, right? I just want to make sure that you're the one doing it instead of having someone else come in. That way, if there's a problem, you can take care of it yourself. I also would thinking building another lower spec pc to use as the backup router with a identical freebsd config makes more sense than using a crap router as your backup. I personally switched to m0n0wall which is freebsd based but runs off of a cdrom and a floppy. I have had bad experiences with the hard drives in pc's I've used as firewalls/routers in the past. I've also moved to using a embedded pc from soekris and that's worked well.
Once you get this going, definately show us some pics and give us a update. This is a very interested project.
jaqie said:its not quite outsourcing AND its not going to hurt our bottom line because it will be a cash thing, not the kinda thing that goes on the record. We will pay him for it out of our own pockets... and we plan on learning FreeBSD very well ourselves to boot. Sorry I have been gone for a bit but my system went ape. vidcard problems, and DVDRW problems. I have it sorted now thank goodness. had to update the bios/firmware in both to solve them.
Yes I plan on keeping everyone well informed on the goingson, that's for sure.
And again, thanks for all the help!
*sigh* now to reinstall all my programs...
