Madalienmonk
- Jul 7, 2006
I'm getting the same problems with the new card as I had in this thread: http://hardforum.com/showthread.php?t=1667443
P6t Deluxe V2
1600 ram
i7 920 stock
Corsair 750 psu
The problem:
I get these flickery horizontal purple/blue lines . I put the 7970 into my brothers comp and had no problems. I've tried moving it to different slots, tried different power cables. Also, when I put the card into my brothers comp, when the BIOS etc load on bootup, it takes up the full screem, like my previous sli gtx 260 and every other computer does. But when I put the 7970 into my comp the BIOS etc doesn't take up the full 24inch screem, there's a ~1" gap on either side, basically not widescreen. wth is going on?
EDIT: I'm starting to think its something physical, because when I mounted the card again its working ok. But it did this yesterday where it looked like it was ok after playing Crysis 2, then BAM artifacts
P6t Deluxe V2
1600 ram
i7 920 stock
Corsair 750 psu
The problem:
