chinesepiratefood
- Oct 8, 2005
I have a Q6600 (G0), GA-965P-DS3 (rev 1.0) and rest of rig in the sig
I can boot fine into Windows @ 3.1 (9*344), and it is prime stable (max core temp on prime is 52), Intel Burn Test Stable (max core temp on IBT is only 60c)
Currently running at 1.37 vcore, stock fsb, mch voltages
The problem is if I try to go up just 20-30mhz I can't even boot into Windows (it does post)
I have tried all the way up to 1.48 vcore, which I just didn't want to go any higher than that.
When I had my E6300 it ran fine at 7*444, so I know its not a FSB issue
Is it possible that because I got this motherboard in 2H 2006, it isn't fully capable of running overclocked quads, because I get pretty significant vdroop under load?
Thanks
Thanks
