miazmaticdotcom
- May 3, 2003
For our next LAN party, my mother (yes, you read that correctly) had a really good idea which I've since implemented, but only on a small scale.
Basically, we've used Alcohol 120% to image all the discs we need to run games onto the file server. We also have a primitive database of CD keys. People can mount the images off the server, and use them to install and play, while marking in the database that their CD key is in use.
Everything is running at 100MBps. The server has two 100MBps NICs, and even though my game box has gigabit, everyone else's won't when we go to the party.
We've tested it with Quake 3 and Raven Shield, with two computers (mine and my brothers, his is only 100MBps) mounting the same image off the server at the same time. They run pretty well with just two machines, but there's going to be 8-10 people at the LAN party.
Server is a 1.6GHz Pentium 4, 768MB RAM, and like I said two 100MBps NICs. It runs Windows XP Pro.
Also, do I need to create some kind of link ("duplex") between the server's two cards to make them run faster? How would one do this in XP Pro?
