I'm running through some design documents for an upcoming structured cabling project and it reads as follows.
Does anyone know what a serpentine design is? I've tried searching on google but can't find a picture or any documents describing exactly how you go about using this serpentine method.c) The contractor shall provide a minimum of 10 feet of cable slack at each MDF/IDF, and a minimum of 3 feet of cable slack for each workstation outlet.
i. Do not form a loop with the cable slack at either end of the run. A serpentine design should be used if possible.
