Mansize_tissue
- Jan 1, 2007
Background (for the ones of you who care): I'm a 16-year old student in the UK about to sit my AS-level exams. Being an avid gamer, i've put up with my aging laptop for long enough and decided to put the money i've been saving to good use. I decided to put this build off until i've finished my exams which, i think, are around June 7th, so i'll actually have to time use it. From my part time job i've gathered around £2100, however this is not the limit to my budget. Since i'll be buying the majority of this build from Scan i don't have to pay until February next year, although i'd like to keep it under £2300-ish because i also have to fund university next year. That should do here!
Right, here's the spec. i've put together so far.
£141 E6600
£168 eVGA 680i
£415 eVGA 8800GTX KO ACS3
£200 Silverstone OP1000
£165 CoolerMaster Stacker 832
£70 36GB Raptor
£139 150GB Raptor
£188 Windows Vista Home Premium Retail
£118 Crucial Ballistix PC2-6400 2x 1GB (2GB)
£341 NEC 20WGX2
£36 Thermalright Ultra-120
£13 Scythe S-FLEX 1600RPM
£22 Samsung SH-W183 18x18 DVD±RW Serial ATA Dual Layer ReWriter (Black) - OEM
Total: £2045 inc. shipping.
If you're wondering: why a 1kW PSU? Then here's your answer; I would like to future proof this in as many ways as possible but, due to the rapid advancement in hardware, i understand this is near-impossible. However, there are some areas where i think it is possible to have some sort of future-proofing; one of which is the PSU. I also think the same goes for the monitor, case and hard drives, since these are all parts that are likely to remain in the system the longest and be recycled the most. Therefore, in these areas, i can jusifity spending a lot. This is why i've chosen these hard drives, case, PSU and monitor.
I do have a few queries, though. I am very worried about memory compatibility with this motherboard (the eVGA 680i) so any help would be greatly appreciated. Here's a shortlist of memory i am considering:
£206 G.Skill PQ 2x 2GB (4GB)
£100 G.Skill HZ 2x 1GB (2GB)
£89 G.Skill PK 2x 1GB (2GB)
£117 Corsair Dominator PC2-6400C4 2x 1GB (2GB)
£176 Corsair Dominator PC2-6400C5 2x 2GB (4GB)
£94 OCZ SLI-Ready PC2-6400 2x 1GB (2GB)
So, what do you think'd be best in terms of both compatibilty and performance whilst considering the price, too.
I also don't know whether to get one of the following cases instead:
£180 CoolerMaster Stacker 830 Evolution (Silver)
£170 Silverstone TJ-09B-W
Again, you're opinions will be valued.
And once more for monitors:
£206 Samsung 206BW
£282 Dell 2007WFP
So, what d'ya think?
I intend to overclock this rig to around 3.2Ghz to 3.6Ghz and there are a few things i'm likely to add down the line, including:
Headphones (likely either: Medusa 5.1 or HD595s, it depends whether i really need surround sound for games).
New speakers (probably Logitech Z-5500)
Sound card (Create Sound Blaster X-fi Extreme Gamer- although, i'll probably spend the extra money to get the Platinum version so i can have the front drive bay for my cans)
And.. i think that's about it.
It's late, so there's probably parts and information i've left out so i'll probably be updating this soon.
Fire away; your comments will be most appreciated.
£141 E6600
£168 eVGA 680i
£70 36GB Raptor
£139 150GB Raptor
£341 NEC 20WGX2
£206 Samsung 206BW
£282 Dell 2007WFP
