Nice! Now the question has anyone been able to mount it on site or did you have to dismantle your loop and all that hassle to install it?
I guess I should do it anyway because my radiator is entire full with dust. But I am tired to messing with this stuff my next computer will be air cooled since I constantly fail building quiet WC setups anyway. Just get to greedy with overclocks.
Otherwise it doesn´t matter which slot you put the GPU in. I have a SLI mainboard the computer would boot also while using the second instead of the first slot?
