I have a system that is exhibiting a bizarre CPU load profile with the SMP client. I tried Windows and Linux SMP clients and they both demonstrated the same wild fluctuations in CPU load. Basically, the graph in Task Manager shows unsteady, jagged lines and Core Temp application does not report a continuous 100% load on any core. The percentages jumps like crazy between 100% and much lower loads percentages.
Furthermore, temps are very low on each core of both processors. Performance in the SMP client is nearly half what it should be compared to other systems with similar specs in my farm. It's definitely not memory, I tried so many modules it cannot be anything related to that. Anyone see this or can recommend what I can do to test the system for problems?
