I was interested to find out how far I could push my OCZ Platinum Rev. 2's the other night, so I decided to venture into a little overclocking quest. I was able to get the sticks to DDR610 with 2.5-4-3-8 timings at 2.8v, passing loops of Memtest86+ v1.51 (on my 3/10 dfi nf4 ultra-d bios). I thought I was one of the semi-lucky ones who could get their TCCD chips past DDR600, so I booted into windows. Everything went fine until I started up CS:S. Halfway through loading up, the game just crashed and my computer restarted. I was like ...when the computer fully loaded, I ran the Super Pi tests. The small tests went by alright, but when I ran the 1M test, the test failed. I dont quite remember what the error messages said...
I left everything in the bios exactly the way they were but changed the FSB to 250. Booted into windows, ran the same SuperPi tests and they still failed.
My CPU is an Athlon 64 3200+ Winny, I lowered the multiplier to 6x along with..I"m not sure what the correct word is, I think hyper transport bus (?) to 3x. I have the DFI LanpartyUT nF4 Ultra-D mobo with 3-10 bios.
Does this mean my memory can't really work at DDR610?
Should I increase the voltage?
Lower the timings?
How much volts can you feed TCCD for long term, or even short term use? I have mine at 2.8v, should I increase it?
Could the problem possibly be from my CPU? SHould I increase the voltage on that? Its at stock right now.
Lower the timings?
