IronChefMorimoto
- Apr 14, 2002
OVERVIEW
I just added an SATA RAID to my NF7-S 2.0 motherboard -- using the onboard SATA RAID controller and two (2) Maxtor SATA 120GB hard drives. As you can see from the specs below, I have an AthlonXP 2500+ (stock) and Radeon 9500 Pro 128MB also in the system. It's powered by a 480W TruPower Antec PSU, and I cool the whole thing with 5 80mm fans (one on the processor with a Thermalright SK-7 copper heatsink).
Before I added the RAID, I was getting idle temps of around 35 degrees Celsius. I get the same idle temps now, but instead of going up to about 40 degrees Celsius at load, I'm now getting up to 50 degrees Celsius.
I ran, for example, a full Norton Anti-Virus 2003 system scan for about 15 minutes just a short while ago, and the temps rose from 36 degree Celsius to nearly 50 degrees Celsius.
I should note that I'm taking readings from Motherboard Monitor 5.3.5.1, I believe.
ADDITIONAL INFORMATION
I'm running one of those standard Chieftec Dragon aluminum cases with room for 4 80mm fans. All of the fans are Panaflo fans connected to a baybus -- they run at the lower baybus voltage setting for noise purposes. Turning them on full tilt doesn't really help too much.
The one front 80mm fan that's housed in a drive cage was PREVIOUSLY blowing over the two RAID drives. When I noticed the temp increase, I shifted them UP to the drive cage with the 3.5" floppy drive, where I previously had two (2) 20GB ATA100 drives. No change in temperature.
The one change I DID make was moving one of those ATA100 drives UP to a 5.25" drive bay -- under two (2) optical drives. This drive is used for Adobe Photoshop work disk. Disconnecting it and NOT letting it run, however, did NOT improve the temperature change that I noticed.
QUESTIONS
QUESTIONS
- Does the SATA RAID controller add to the load temperature of an NF7-S 2.0 system, either from the processor side or from two hard drives being accessed simultaneously?
- Would the BIOS upgrade (from 15 to 20) also cause the CPU temps to read higher at load than previously?[/list=1]
I'm not sure if this is related, but I also noticed that, upon a recent boot earlier in the day, the BIOS RESET the CPU settings and gave me a warning at boot about checking the CPU for some reason. I had to reset the BIOS to the 2500+ setting. It was rather odd.
Could I perhaps purchase a PCI SATA RAID card, drop it in, and have it pick up the RAID 0 that I'm already running? As a means of ruling out the temperate rise from CPU/onboard RAID question?
Would a PCI card allow me to bring in an existing RAID? esp. if it's on another chipset?
Any help that you [H]ard folks can offer is greatly appreciated!
Thanks,
IronChefMorimoto
