Hey everyone
I'm helping my friend build a new computer and he's a 3D animator.
To answer the default [H] questions...
Thank you. This will help us immensely.
Note:
I did do a search for 3D builds and found this
http://hardforum.com/showthread.php?t=1403878&highlight=build
But his budget was $2000 and he wasn't planning on using it for gaming
- It will be for 3D modeling (Maya), video editing and After-effects. Plus gaming
- Budget is around $1000 - $1200 (w/out monitor)
- We live in the United States
- We Need everything. Including monitor choices...
- We'll be reusing no old parts
- Won't OC
- He doesn't have a monitor. We're thinking of dual 24" possibly...
- I plan on building it ASAP. It is spring break
- No need for SLI or RAID. We want to go with 1 high-end video card
- As for the OS...should I use XP or Vista and utilize 4+GB of RAM?
Note:
