Treyshadow said:
2x1 Gig 2-3-2-5 sticks
Currently running 2.5-3-2-5 on my box at 250x10
Hmmm, everything I've read pointed to bad OCing patrior 2GB ram... Let's see how my OCZ pans out when it comes..
(cf)Eclipse said:that'll cause serious issues unless you've got a revE core
grendelrt said:I am currently running 3x512mb right now on my XP setup and saw this comment. What kind of things do I have to look out for when I upgrade to a A64 Setup? I am planning on going X2 anyways, but I was just wondering what issues you were speaking of, always good to have a broad outlook on things =)
infiniti029 said:I'm getting an MSI Neo4 Plat w/ Venice 3000+... i was wondering the same thing cuz i'm in the same situation (3x512). In my current rig I HAVE to have at least 1.5GB of ram for BF2 or the game starts to choke occasionaly.
misterE said:thanks for the post OP, was exactly what i was looking for. I'm going to be getting 2gb (4x512mb) of ram next week and have been looking into both crucial xms, but lately have been leaning towards mushkin. I hear the redline is good, but wondered if anyone had experience with these:
http://www.newegg.com/Product/Product.asp?Item=N82E16820146355
Should be similar, but better performance, just wondered if anyone had experience with them (i've owned other mushkin mem in the past and have been very happy with it). I'll do minimal if any OC'ing.
misterE said:i have an x2 3800+ and my primary concern is gaming, so from what i've read here, 4x512 will perform better for what i want.
Yes, it seems to be performing very well. I'm currently running at stock speed (i.e. no overclocking) and the timing does show up as 2-3-2-5, which is consistent w/ the stated specs. If you plan on OC'ing a lot and want 2x1 GB, then, this won't go too far before you have to loosen the timings. And even after loosened to something like 3-3-3-8, from what I've read, it still doesn't OC that much.AthenaX said:beowulf7 Curious on the OCZ Sticks?? Are they performing well?? I'm lookin at buying the same..
You're welcome. I know exactly what you're going through. I built my first system ever (from scratch) and went through the entire process, through good and bad. My PC project literally started in Jan. when I bought my case. I got serious about buying the other stuff when I decided I was going to get my mobo and CPU from the AMD Tech Tour (which was held in late July for the NJ show). I finally flipped the switch 2 weeks ago and am now installing stuff and trying to transfer files from the old PC to this one.AthenaX said:Thanks for the quick response.. Putting together a new system can be a pain, when faced with millions of reviews.. Yes there will be overclocking.. Thats why its got me scratching me head on the RAM.. Definetly going 2 x 1gig.. Leaning again to OCZ.. Heres another ?.. On newegg theres Two 2 x1gig kits from OCZ ones more expensive.. but the only diff looks like the heat spreader.. True?
I assume it would since you still have 4 memory sticks in there. If you can sell your 4x512 MB of RAM for a decent price, I'd recommend in doing so and then get 2x1 GB of RAM.Tiny said:Dang.
EDIT***
Wait....what if I want to run 4x1gb memory...will I run into the same problem as I had with 4x512?
beowulf7 said:I assume it would since you still have 4 memory sticks in there. If you can sell your 4x512 MB of RAM for a decent price, I'd recommend in doing so and then get 2x1 GB of RAM.
BTW, did you try removing a pair of sticks to run 2x512 MB to see if that memory boots up at 400 MHz instead of 333 MHz? Also, are you positive the Crucial value RAM you bought is indeed PC3200 and Not PC27000?
If you don't overclock and want to get the fastest 2x1 GB memory for a "reasonable" cost, get OCZ Platinum, which has 2-3-2-5 memory timings.Tiny said:Yup. Tried them in every way I could...one in, two in, one in the first bank, one in the second bank and one in the third bank...etc... All booted at DDR400 except 4x512mb. 3x512mb booted at DDR400 too.
One of the reasons I bought this motherboard was because it could hold 4xmemory.
Since I am only running 2gig of memory now, I could just buy 2x1gb mem sticks and be happy for a while.
What should I get so I run 1T? I have no knowledge when it comes to timings.
And take into account that I don't overclock...nor will I ever.
beowulf7 said:If you don't overclock and want to get the fastest 2x1 GB memory for a "reasonable" cost, get OCZ Platinum, which has 2-3-2-5 memory timings.
That's why I said "reasonable" price.Tiny said:Cool thanks.
$269 isn't that cheap, but I can offset it by selling my current sticks.
They should ban you from these forums for life for saying such things.Tiny said:And take into account that I don't overclock...nor will I ever.
(cf)Eclipse said:two things:
1. there's no telling if your memory controller can actually handle 4 sticks at 200mhz. some don't, thus the 166mhz, 2T rating.
2. show me a via based K8 board that consistantly does >240mhz
robberbaron said:Hello fellow forum goers. I have noticed an increase in threads asking which would be better of these two choices on an Athlon 64/Sempron:
- 4x512mb
- 2x1024mb ram
Here is some "realworld" gameplay data for CS:Source.
1280x1024, all high, 4xAA 8xAF
2.5GHz with 192MHz memory
1T: 92FPS
2T: 90FPS
However, let's see what framerate I'd be getting with a full 10x250MHz 1:1
1T: 109 FPS
2T: 108 FPS
er, why do you say that. even at 2T, the K8's bandwidth efficiency and latency is far better than any intel or K7 based mobo at equivilent speeds and timings. hardly "crappy" in my bookMalogato said:I was not aware that the amd64 memory controller was so crappy that It could not properly handle 4 main stream memory modules.
(cf)Eclipse said:er, why do you say that. even at 2T, the K8's bandwidth efficiency and latency is far better than any intel or K7 based mobo at equivilent speeds and timings. hardly "crappy" in my book
