Hey guys. ive been thoght the A8N sli deluxe,MSI NEO4 SLI and now im on the DFI nf4 sli. now my problem is that. the dfi only has 2 pci 1x slots now that makes a problem since i run and Sound blaster augidy 2zs and a ATI 7000 pci. along with my 2x 6600gts. now that would be all well and good BUT. i cant oc my GFX cuz the heat and from both the 7000 and the 6600. the only solution i can come up with is WC the 6600gts with the Innovatek Cool-Matic 6600GT PCI-Express GPU+RAM Cooler. now Those coming in at 140$ each. that is a much more expensive solution to the alternitive which is but a new mobo Again with 3x PCI 1x slots. so i can have room for my Zalman 700-cu coolers. which would be under 200 and not 300 like the WC would be.. Now you might be saying this guy is retarted cuz he bought three mobos knowing that they only have 2x pci and needed 3. not that case the 7000 is a new edition to the rig with the seconed 6600gt. which made the problem.....
So what is the best 3 slot pci mobo and can i bring the vcore above 1.55 with my 3000+ wincester??????????
THANKS if you read all that
