I have an old Thermalright XP-90 and want to use it on my AM2 build and I have no idea whether it is compatible or not. Do I need to purchase a new mounting bracket or something? Any help would be fantastic.
Yes, just get the thing ToasterOven posted, should work. I just got the LGA 775 bolt through kit so I could use my XP-120 on my new build and it worked great.
I've orderred this part and am trying to install it. However the plastic clips that hold the RM to the motherboard don't seem to fit the holes on the new RM. Is there something else I should have bought?
