Gentlemen,
I finally got my hands on this beautiful piece of CPU Cooling Art. Although I agree that it came with nice instructions and great pictures, I must say that the folks over at Thermaltake have neglected a rather fundamental aspect in their directions: bolt torquing tips. I have read a few horror stories where motherboards have been flexed so much by improper tightening while mounting this 'brick' that the pcb cracked. I was therefore very cautious while tightening the base to the bottom of my D875PBZ and continuously checked her profile to ensure she wasn't warping.
I have two problems right now and I would be immensely grateful if some of you could enlighten me:
1- Not having yet decided which 90mm fan will move enough air while being reasonably quiet (for an exhaust setup) I temporarily bought two cheap 80mm fans equipped with 3pin motherboard connector. Well, these fans spinned kinda slowly and I kept on getting these alert messages from ActiveMonitor, so I disconnected them:
The interesting thing is that even now that they are disconnected, I STILL get the above error every few minutes! What gives? There's nothing plugged in the CPU Fan connector on the motherboard, so ActiveMonitor is complaining about it, but the above error is something completely different and kept on appearing even when the fan were connected, so they are not related... here's a portion of the Alert History:
Please let me know your opinion, this is really a concern to me.
Best Regards,
Walter
2- Is there a website out there with suggestions on how much to tighten the bolts on the Tower112? I have done my best by eye but I would much rather read some other opinion out there to ensure that my Mobo is being flexed the least possible and the contact with the CPU is optimal.12/26/04 12:14:08
A voltage (+12 V) has returned to its recommended range.
12/26/04 12:14:07
A voltage (+12 V) has gone outside of its recommended range.
Bad Voltage Value: 3.375 volts
12/26/04 11:41:15
A voltage (+3.3 V) has returned to its recommended range.
12/26/04 11:41:14
A voltage (+3.3 V) has gone outside of its recommended range.
Bad Voltage Value: 0.584 volts
12/26/04 11:13:10
12/26/04 11:13:09
Bad Voltage Value: 4.383 volts
12/26/04 11:11:56
12/26/04 11:11:55
Bad Voltage Value: 0.602 volts
Best Regards,
Walter
