I have an X-Fi I/O Drive that I just installed. It uses a floppy power connector, and long story short, I wasn't paying attention when connecting said power connector. I turned on the system, heard a couple short fizzles before the system powered up, and the drive wasn't working. I opened up the case again, pulled out the connector, and one of the pins on the I/O drive is now missing (so much for resale value ).
Going from left to right, the power connector is yellow black black red. The now missing pin is the one that would connect to the black nearest yellow on the connector. The likely cause is that I didn't see myself misaligning the connector and missing one of the pins on the drive, so I ended up grounding the yellow 12V line causing a short somewhere. I'm not sure why I decided to just replug the connector, this time properly, and to my amazement the I/O drive still works even with only 3/4 of the pins available.
I'm just curious on whether it's safe to leave it like this with only one ground wire connected or if I should play it safe and disconnect the thing permanently. The yellow wire connector end has some...extra metal probably welded onto it now from the dead pin from the I/O drive too if it makes any difference.
