robberbaron
- Sep 6, 2004
This is really embarassing but, I'm totally out of the loop for Intel these days. My initial reaction to buying an Intel system would be to get a DFI board and CH-5 and a 2.8E, however, that probably isn't the best course of action, haha.
So, are there any mATX boards that are worthwhile OC'ing wise? Finding reviews on mATX boards is a difficult task. Basically what I want is to spend as little as possible to get to 3.6-3.8GHz with Hyperthreading.
The lowest multi on a Prescott is 14 right? No possible way to go lower? Because, I'd really like to try high speed DDR2 at 1:1 but doing such a thing would be difficult on air cooling.
14x400 = 5600MHz. Do DDR2-800 is out of the question.
Though, if I were to run async, what performance issues would I hit if any? Are the memory cycles basically wasted or will they just improve the latency and make the system snappier still?
Bear in mind that the last Pentium 4 system I used was a 2.4 Northwood with a 400MHz FSB and RDRAM. OC'ing of things was rather out of the question since it had a Dell motherboard.
So to sum it up, I want a cheap toy and don't really give a damn about it's future (65nm can go to hell, 130nm is all I'll ever need haha.) My max price would be $300 for the system+cpu+SFF case.
Also, are VIA chipsets as bad for the Netburst as they are for the Hammer?
Because this looks interesting:
http://www.newegg.com/Product/Product.asp?Item=N82E16813123248
Also, this case:
Is 5A on one 12v rail and 13.5A on the other 12V rail enough for a prescott+6600GT? I know the 13.5A rail should handle the card but 5A on the 12V1 seems... yeah
Oh and it needs to have 64bit support. The 520J does not have this, correct?
Also, this case:
