I have a few questions. I'm going to start with the 15.4" widescreen T61 configuration and upgrade a few parts.
I would like to go with XP Pro, but I'm wondering how much crap is going to be installed when I first boot it up. Is there an OS reinstall disk so I can wipe it and start with a clean slate?
I would like to order the T61 with the cheapest RAM option and buy a 2GB kit on Newegg to replace the stock RAM. Is it easy to replace the RAM in a T61? Will there be any compatibility problems with this kit for instance?
Other than that I plan on upgrading to the WSXGA+ screen, T7300, 80gb 5400rpm, and the DVD Recordable 8x Max Dual Layer, Ultrabay Slim Drive.
Thanks for your help,
Oline61
Oline61
