This may be more of a "I need to write this down" kind of thing, but any suggestions would be most welcome. I realize this isn't a specialized HTPC forum, but smart people roam these hills and I'd like to pick some brains (Crimandevil, idversusego, valve1138, others: ASSEMBLE!)
First I'll just list what I have as of this moment:
1. Living room
- Athlon64 3800 Venice
- GeForce 7600GT
- 1GB DDR400 RAM
- Hauppauge 500MCE (SD tuner)
- Hauppauge 150MCE (SD tuner)
- SBlaster Audigy2 ZS
- DVD Burner
- (2) 320GB PATA HD (Media Storage)
- (1) 80GB PATA HD (Contains OS)
- Housed in purdy HTPC case
- Hooked up to Standard Def TV via s-video
2. Bedroom
- AthlonXP 3000+ 400fsb Barton
- 1.5GB DDR400 RAM
- Radeon 9600xt
- 80GB HD (OS, light media)
- Avermedia 180HD (ATSC HD tuner)
- USB Soundblaster NX
- Housed in Lian-Li midtower
- Hooked up to 17" LCD via DVI
I've been using Windows MCE without any major problems for a few months now. I'm satisified with the way it works. Except it doesn't allow for networking very well. Crazy filesharing and registry changes are needed to get things working, etc.
Recently I pieced together my Bedroom HTPC with spare parts and decided to give HD a go by getting the Avermedia card and an antenna. I couldn't get the Avermedia card to be recognized in MCE (I had one of the Hauppauge cards in there at the time). So I decided to give SageTV a whirl and everything worked great immediately. I also downloaded the client trial and put it on my laptop and could stream HD.
So, basically, I've decided SageTV is in my near future. Here's where the questions come in...
What would be my best setup using my current parts (plus a few additions)?
I'm thinking I should build a server. Should I take my Lian-Li case and put all tuners and all large format Hard Drives in it? I could install SageTV Server on it as well as have all my DirecTV boxes in the room with the server. The room is, coincidentally, the hub where the DirectTV is split to go all over the house.
This would enable me to continue using my Living Room setup and eventually add an HDTV. All I'd really have to do is install SageTV client, right? I'd also buy an additional HTPC case and use that for my bedroom.
Sooooooo....breathe.....here's what I'd end up with in my mind:
1. Living Room
- Everything in above setup minus the tuners and big Hard Drives
- New LCD tv
2. Server
- Lian Li Mid Tower
- 80GB Hard drive for OS/programs
- All big Hard Drives currently totalling 640GB (will buy a few more for 1TB+ of storage)
- All tuners (3 Hauppauge SD, 1 Avermedia HD, and most likely 2 more Avermedia HD)
- New mobo (most likely with integrated everything)
- Move 17" LCD into server room for upkeep/problems that arise
- Missing anything?
3. Bedroom
- New HTPC Case
- keep same vid card, memory, mobo, etc.
- New 20-24" LCD
So, as I said before, half of the purpose of this post was to spew my thoughts. If anyone has a similar setup or sees a gaping hole in my plan, please chime in.
1. Living room
- GeForce 7600GT
- 1GB DDR400 RAM
- DVD Burner
2. Bedroom
- 1.5GB DDR400 RAM
- Radeon 9600xt
1. Living Room
- New LCD tv
2. Server
- Lian Li Mid Tower
- Missing anything?
3. Bedroom
- New HTPC Case
- New 20-24" LCD
