So, I've been having trouble trying to get this thing to go any higher. It runs great at 333x9, but i just haven't had any real success with anything higher lately. A few months ago I had it at 3.4 for a while (when system was brand new), but i pulled it back when i went to 8g of ram (yes i need and use it). After i added the 2nd 4gigs it crashed a couple times so i went to 3.2, then it still crashed a couple days later. So i'd settled at 3.0 as it seemed rock solid stable.
I've thought since then that the bottleneck was likely my nb/ram (4 dimms, ddr2 800)
Anyway, I've managed to resist pulling the trigger on wc gear all week, so last night i thought i'd try to push the system regardless of temps (to a point of course) just to see if it would run at all. No point in wc'ing if it just absolutely refuses to go higher regardless.
To my surprise, w/ a considerable voltage bump i got it to boot and actually do stuff at 400x8. But it still throws errors immediately on prime. But anyway i figured that this was evidence that my problem was indeed just the proc. and not issues w/ having 4 dimms <-> NB voltage etc. etc.
NEwhoo before i finish writing a book here's some before / after settings.
333x9 = 3.0 @ 1.38v (bios, approx .04 droop = 1.33/1.34ish)
ram at 667, 5-5-5-15, 1.925v (ram's specced for 1.8v, but its cheap so i don't mind bumping it)
NB @ 1.6875 (I think, maybe 1.65, will verify when i get home)
I had to bump the ram up from the 1.8 and the NB up a bit from stock, otherwise it would occasionally give me a bsod mem dump.
So for the attempt:
400x8 = 3.2 @ 1.425 bios (approx 1.38ish)
ram at 800, 5-6-6-18 (<- will verify), had to bump it to 2.1v, won't run any lower.
NB voltage unchanged.
So at this it would boot up fine and let me fart around. I even shot off a render from 3dmax and let that run for a while, it seems to run fine (this is usually and easy indication for me if there's any memory problems, it would bsod very quickly). However the cores error on prime blend test immediately. I've pushed the cpu bios voltage all the way to 1.5, approx 1.46ish actual, and other than pushing my temps it does nothing.
So i'm just wondering, is there possibly a different component that i need to be adjusting? fsb voltage/sb, etc. etc.? I'd really like to put it under water, but i just can't justify it if it's still not going to go any higher than 3.0 even if i volt the living hell out of it. I really don't mind even putting the whole chipset under as well if it might help get this thing over the hump. In a perfect world I'd like to be able to cool it enough on h2o to just volt the crap out of it to 3.6.
Sys specs.:
q6600 slacr
xfx 780i
2x gtx 260's sli
850w tt psu
and lastly, thanks to those who actually had the patience to read my rambling.
So for the attempt:
Sys specs.:
q6600 slacr
xfx 780i
2x gtx 260's sli
850w tt psu
