macksomerville
- May 18, 2000
Long story short...
Comp wouldnt reboot after moving... reset the Bios.
Raid wouldnt boot (missing two drives)
Check power and sata cables
Reseat everything
Drives recognized but now the two disks are Non-Member
try everything under the sun (disable raid, reenable, intel software, etc, etc)
There is nothing I could do or find out so I decided to just redo the array.
Question is now... is there anything I can do to prevent this from happening again or a suggestion for a controller that could of saved the array (lots of pictures) since the drives work but just dropped from the array for whatever reason.
Reseat everything
