Wrecked Em
- Sep 14, 2004
Hi,
I'm trying to come up with a solution for a fitment problem with a VID-AR797 water block. My card is a XFX #FX797ATDFC, which I was led to believe followed the reference layout. Unfortunately, a row of board components (choke coils maybe?) is making contact with the water block and holding up the back side of it.
Anyone have any suggestions for how I might make this work? I'm certain I've torn into my video card far enough that it can no longer be returned, and I've already started applying pads to the waterblock, so I'm not sure if the reseller will take it back either. At this point I'm not opposed to getting creative, but I wanted to check and see if anyone had ideas for a simple solution.
