Speed isn't the main factor, airflow is. I would think the fan with higher airflow should be pulling and the weaker fan should be pushing, but it probably doesn't make much difference either way.Ok, so if you were to have two fans at different speeds, should the higher speed one be pull and lower be push? Or vice versa?
Thanks for the advice. Is there a certain tape to use so there is no sticky residue when I remove the tape?
Hmm... So an alternative solution would be a nice, think 120mm fan...
But then how do you fit it onto the heatsink? I imagine the fan clips do not stretch that far.
