Trying to find usb motherboard header plugs
ChoGGi
I suck at searching it seems, so I hope some kind soul can show me where to buy a couple dozen of each of these.
Please and thanks :)
Digikey should have what you are looking for: DIGIKEY
they should but i could not find them on there...
Cho, youre looking for 1x5 and 2x5 2.54mm dupont berg connectors. i can find them but was unable to find you a canuckistani seller...
2x5 Pin Dupont Berg Housing 2.54mm Connector | Sharvielectronics: Best Online Electronic Products Bangalore
1x5 Pin Dupont Berg Housing 2.54mm Connector | Sharvielectronics: Best Online Electronic Products Bangalore
Dupont Female Crimp Terminal Contact 20 To 28AWG | Sharvielectronics: Best Online Electronic Products Bangalore
you can get kits on amazon but theres only about 10 of the ones you need per kit.
