http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=16829567
Any way I can improve it?
Heck, I didn't even know there was a 4860 until now. There doesn't seem to be much about them on the internet. As for the case, too bad you didn't get it around Black Friday. I got the Antec 300 from newegg for $50, plus an additional $20 off after MIR, so only $30.Thanks so much. Could you check my wishlist real fast?. He said he can go up to 650ish. My main issue is between the EA650 vs the VX550. The EA650 is cheaper. Which would you suggest? Also, would you choose the 534, CM 690, or Lian Li PC-56KW?
Also, one outtake 120mm should be sufficient for cooling, right? This build will not be overclocked. I chose the 4860 due to the it's price and theoretically it should perform just under the 5770.
I think that's everything, thanks.
Frankly, in my opinion, HG's build is better than your wishlist.
1. The Phenom II X3 720 is a better choice than that x4 you chose. While the x3 720 does have one less core, it has the potential to unlock the fourth and it is multiplier unlocked. That is important to me, though not sure if you friend would care.
2. Seagate 500GB HDD is faster than the WD640GB as it has a higher density, 1 500GB platter vs 2 * 320GB platters on the WD. To top it off, it is cheaper.
3. 5750 is a much more future looking GPU than a 4XXX GPU.
If you want to spend some more money (using HardwareGuru's build as a baseline), you can easily. Bump up the RAM to 4GB of DDR3 1600 for ~$10, grab a better case (say the CM 690) + $10, and say grab a beefier PSU (Antec EA650 +$35). That would put you at a little over 650.
In terms of case, that is a completely subjective and personal choice. I'd have your friend choose the case after reading reviews and looking at pictures. Now if you are going to actually assemble it, then perhaps you could nudge your friend to a case which you'd like to work in.
One 120mm fan would be sufficient for cooling.
phenom II x3 720 + gigabyte 760gx
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.295032
sapphire hd 5770
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102864
(http://www.newegg.com/Product/Produ...0048 106793261 1067950041&name=Radeon HD 5770 options for all 5770 should you like another vendor)
