TIA for any advice you can give, here is the setup:
Evga GTX 660 superclocked
Dell 2405fpw (19x12 resolution) connected through DVI-I
Yamaha 5.1 receiver connected through HDMI
I want to use the HDMI port to output audio only, and the DVI port to output video only. The only time that I can get the audio to work, is when the computer is set to dual displays and "duplicate display" so both the HDMI and DVI receive the same signal. The problem with that, is that the Yamaha receiver can only receive a 1080p signal max, which limits the resolution of the Dell 2405fpw to 1920x1080 instead of it's native 1920x1200.
Can anyone give advice on how to output audio ONLY through HDMI? The motherboard is a Biostar TA890GXB with an HDMI output, however, I was unable to get audio output to work through that as well.
