Im trying to reformat windows xp pro, and im at the command prompt, and when I do format c: it says you will loose info etc and I do yes... then it says
"Format cannot run because the voulme is inuse by another process. Format may run if this volume is dismounted first. All opened handles to this volume then would be invalid. Would you like to force run a dismount on this volume, yes or no.... and I do yes and it still doesnt work.
What should I do?
What should I do?
