Hey guys, I'm close to buying a tuner card and I'm not quite sure where to go. I'll basically be using it to record but I want to be sure it will still be able to be used after next February.
Right now I'm looking at the Sapphire 650 Pro or the Hauppauge 1600 MCE. I can't tell if the Sapphire will be compatible after the switch to digital stuff, and I've heard of issues with Hauppauge and 64-bit Vista.
What's the better route to go? Or is there another alternative that is in the same price range (around $100 or less)? Thanks.
