I asked this question here a month ago, though in a rather round-about way, and didn't quite get the answer I was looking for, so I'm revisiting the topic. I'm trying to figure out a way to have two completely separate computers on one computer's hardware. I want to be able to switch between them easily each time I start up, with either the press of a button, or the flick of a switch, no messing around with things inside of the case. I want to be able to load one with spyware and keyloggers(just for example, I don't actually do that ), and have the other be completely unaffected.
I found someone else asking the same thing here. This is one of the answers he got-
Would this accomplish what I'm looking for? It sounds fairly simple and effective, exactly what I'm looking for, but I don't know if it will work.
I do run anti-virus and anti-spyware, and I know how to protect myself, but its the principle that matters to me. For all intents and purposes, I want to have two 100% separate PCs, while only taking up the space of one, and only paying for one.
Install your production Windows on the first hard drive (the one you've set your BIOS to boot from), then install your disposable Windows on the second drive. The second installation should make an entry in the first one's BOOT.INI, allowing you to pick which one you want during the Windows boot sequence.
Next, boot your production Windows and use the Disk Management console to remove the drive letter from the disposable Windows' partition.
Next, boot your disposable Windows and do the same thing from that side.
Windows won't touch partitions that have no drive letter or mount point defined. The only disadvantage of this arrangement over doing things the BIOS or GRUB way is that if your production Windows goes belly-up, you might not be able to boot your disposable one.
