I need a little advice on new setup for hard disks. I have a large raid array and want to keep that just for critical disk storage of files, pictures, and data.
What I would like to do also is this: 1. Have 2 hotswap disk trays with only one connected to the mobo and the other for physicsl storage another drive while it's not being used.
2. 147MB HD I will install Vista 64 Ultimate on.
3. 74GB HD I will install XP x64 on.
4. I would like the raid array to be used by both operating systems one at a time of course.
But am unsure of how to set this up. Should I install the OS's on there respective disk first and then create the raid array with the other 8 drives or should I do the array first?
The other thing I do not know about is if this will work or will Vista want total control of the array and make it impossible for XP x64 to access the files?
Any and all help here will be more than welcome.
Thanks in advance.
Oh All these disks are scsi and the raid is on its own hard ware raid card where the OS's will be on there own controller by themselfs.
Thanks in advance.
