Protoform-X
- Jan 30, 2002
I recently installed a UC540 for a small shop and configured it with CCA 2.2. Ever since the initial install the users have complained about "poor quality" or "choppy" audio when using ad-hoc conferencing. I've verified that G.711u is being used during the offending calls. I've also verified that the phones are on the correct "10.1.1.0" subnet and data is on a different subnet, so QoS *should* be working? I did alter the data subnet from the original 192.168.10.0 to the existing data subnet, so maybe I broke QoS? I guess it wouldn't make a whole lot of sense since 2-way calls seem to work great.
I decided to change the system over to hardware conferencing to see if that would resolve the issue, but it didn't make a difference. The choppyness is still there. I've tested with all 3 phones being internal to the network and the choppyness is still there. Any great ideas or troubleshooting steps I should take?
I'll gladly post the config if necessary, but it will take some time to scrub it.
