Do you need any special router for UniFi if you want to have your office network and then a guest network?
Normally you would need to do a VLAN and then have another DHCP server.
do you need to do vlan? thats what I am wondering.
i am wondering if all this is built into the unifi. at the site we have they dont have a router that can do vlan.
Client Isolation mode works...within other wireless clients..but soon as the traffic leaves the AP and hits the LAN nothing can police it so it can find other nodes on the switch. True client AP with wireless with smaller biz stuff needs to be done from wireless built in a router. Or on higher end wireless controllers that are fed from anutter VLAN. At least AFAIK.
I had one at the office for a month or so, but it got put to use elsewhere...so we don't run them at our office. Got some at clients though, working well....but setup with traditional LAN access. The one I'm doing with Untangle will be the first one truely for guests at a client..I'm sure that will work fine though since it's going to a dedicated Untangle interface.
On the Unifi you can apply guest policies. Basically you'll get an IP from the same DHCP server as everyone else, but you cannot access or even ping anything on the network when it's enabled.
Or you can go with VLAN route and multiple DHCP servers which works really well. That's how mine is setup at home with 4 VLANs just for wireless to give me guest access, internal network, and two test networks with different Public IPs.
Only thing i think is stupid with Untangle is, if yu have 2 NIC ports and add in another, it becomes DMZ, so to get a second port you need to add in two ports.. ..
