So initially my crash dump files were pointing to my mouse being the culprit (I tried uninstalling the Habu software and using another mouse, btw, just to doubel check) but now my system isn't even producing crash dumps because it immediately freezes. It does not respond to anything but a forced reboot via the power button.
I am trying to do my best to find out what is causing it but I am honestly not sure. The crashes happen randomly, in 3D games or just while on the desktop, even at the Vista login screen. I ran memtest86+ and it went through fine. I then ran Windows Memory test or whatever it's called and the system actually froze while in that command line environment. So it's not a OS issue either it seems nor does it particular seem to be the memory. Temperatures seem fine all around, though I removed the overclocks on my CPU and GPU just to be sure. No dice. I checked all the connections to make sure everything was fitted correctly. Sometimes it happens once or twice a day, other times it happens like 10+ in a day.
I am maybe thinking it might be a power issue, Though, my computer is connected to a TrippLite OMNI1000 UPS so it should be getting clean power. Could it be possible that the PSU is starting to die out? It's an Antec 500W something or other from a year and a half ago.
If anybody has any other suggestions as to what I can do to track down the cause, I'd appreciate it. Just seems real odd since the computer has been working flawless since I built in '06.
