Maxtr0sity
- Dec 24, 2005
Core 2 Duo E6750 @ 3.2Ghz
Crucial Ballistix 4GB
Gigabyte GA-P35-DS3L
ATI Sapphire 1950Pro
Recently I noticed my computer has been restarting itself randomly. It has always been stable and since the first time I OC'ed, I've ran Orthos for 8hr+ without issues. I start orthos and what do you know, within the first minute, error occurs. Back to the BIOS, I turn off OC and try again with default everything. Orthos fails again.
Must be RAM right? I remove two sticks of RAM (down to 2GB) and run Memtest on it, passes for 5 cycles straight. Boot back into Windows, Orthos fails. So this comes down to the motherboard or CPU. 3.2Ghz for a 6750 is considered modest. My voltage was set at 1.45 and temps never went above 60C under load. I really don't think the CPU would fail under these conditions. I don't have another machine to test out the CPU or motherboard unfortunately, what else can I do?
