DarkenReaper57
- Oct 2, 2003
Hello everyone,
I've been doing a bit of research as I need to replace my current 350W APC UPS unit. I've found that the max power draw my system pulls (Prime 95 and running rthdrbl) is about 520W/560 VA. As a result, I'm looking for a minimum of a 600W unit, preferably at least 700W.
My max budget is $200 shipped, but the lower the better. I've been looking at this unit: http://www.apc.com/resource/include/techspec_index.cfm?base_sku=SUA1500&total_watts=50. Normally the cost would be huge, but this same unit (refurbished) at UPSforLess sells for $149 with about $25 shipping: http://www.upsforless.com/ibm1500tlv.aspx. I understand that this unit is overkill, but it would be nice to have the extra power handling.
From what I can tell, this unit has true sinewave power output. Does this mean that the UPS is always powering the system without a relay, or is this only the case for "online" UPS's? That said, can anyone attest to the quality of this unit?
Any other suggestions are welcome as well. I definitely want something that will last a couple years minimum, and from what I understand, APC has the highest reliability when compared to other brands of UPS's.
