Satyrist
- Mar 12, 2001
It appears quite possible that the usb ports on my rig have shit themselves.
The motherboard is a Foxconn 6150K8MA-8EKRS, and it might have shorted the ports out. I can see signs of a connection if I hook a usb mouse or the like up to it, (the mouse led lights up) but peripherals are completely unresponsive; Nothing shows up in Device Manager under XP as well.It's not the mouse, as it works fine using a usb-ps/2 converter.
I've got a led usb cable as well, both ends are lit...It goes to a usb printer, which of course isn't being seen either.
Is there any sort of diagnostic software out there that might be able to verify that the ports are shorted/dead?
Thanks.
Thanks.
