First some background:
I had tried Ventrilo back in May without much success. My teammates and I settled on Yahoo Instant Messenger as a result. However, it looks as if our gaming group as a whole will have a dedicated Ventrilo server in the near future. Therefore, I would very much like to be able to use Ventrilo effectively for gaming purposes. I have an ABIT AN-7 motherboard with nForce2 onboard audio. I have downloaded and installed the latest nVidia drivers.
Current situation:
I tried Ventrilo last night. By performing a simple ingame test (typing "1" "2" "3" etc while saying the numbers aloud), we determined that each of them could hear each other as they spoke without any delay. However, while I could hear them as they spoke, they heard me anywhere from 2 to 10 seconds later. From a gaming perspective, this kind of delay is unplayable.
Here are my settings.
I am using Ventrilo version 2.2.0.
In WinXP Pro, I have the microphone input at about 70% and the mic boost box checked. I must check the boost while in Ventrilo. In YiM, I can't be heard unless I uncheck that box.
In Ventrilo setup, I have marked the following under voice:
My question is this: What should I check--what settings do I need to adjust--that will enable me to eliminate the lag my teammates experience when listening to me speak? As I mentioned, I can hear them just fine and they can hear each other. The delay occurs only when I speak.
Thanks.
-ceolstan
System Specs:
ABIT AN7 nforce2
AMD XP 2500+
512 RAM
120 gig HD
LG combo drive
floppy
cable modem connection
WinXP Pro
Current situation:
Enable outgoing voice communications
Play key clicks
Silence Time: .05 seconds
Sensitivity: 3
Output Device: nVidia(R) nForce(TM) Audio
Input Device: nVidia(R) nForce(TM) Audio
Mixer: nVidia(R) nForce(TM) Audio
Mux: recording control
Line: microphone
Hardware is at 6
Outbound is at -4
Inbound is at +10
Thanks.
-ceolstan
System Specs:
ABIT AN7 nforce2
AMD XP 2500+
512 RAM
120 gig HD
LG combo drive
floppy
WinXP Pro
