I have two separate issues.
I have two XFX 6950 cards in crossfire. Shaders are not unlocked / stock bios. From day one of installing these cards GPU1 always showed much higher temps by 10 to 20C from idle all the way to 100% load. If I swap the cards location GPU1 still shows the higher temps. Can this really be a location issue causing 20C difference???
I recently installed Arctic Accelero Twin Turbo II's on both cards. With the appropriate (medium) sized spacers and the stock paste that's pre applied I received the following results within furmark...
note after the coolers were installed I up'd the clock and memory of both cards using MSI Afterburner
idle GPU1 50C 100% 80C
idle GPU2 35C 100% 71C
Not being very satisfied with these results and after some reading of various reviews I decided to remove the spacers (yet taking care not to over tighten the card) and thoroughly cleaned the surfaces (arctic cleaner/prep) and re apply'd paste this time using actic silver 5.
The loaded tests worsened on GPU1 and got much better for GPU2
idle GPU1 45C 100% load 90C
idle GPU2 29C 100% load 57C
ALSO with the Arctic coolers installed any program I use displays the fan tach fluctuating from 2000 to 800,000 rpm. This only goes away if you manually set fan rpm (say with MSI Afterburner) above 60% or so only then will the readings stabilize. (this happens with both coolers / fans)
So my questions are
1) can the gpu location make a 20C difference? or is there something else going on here
2) what is responsible for displaying GPU fan tach (cooler, card, mobo)?
3) how do my test results for these coolers stack up? from all the reviews I read GPU1 really concerns me
My rig
MSI P67A GD65 B3
i7 2600k OC @ 4.2
16GB Gskill ripsaw DDR3 1600 memory
OCZ Vertex 3 Max IOPS edition
Seasonic X650 PS
(x2) XFX HD-695X-CNFC Radeon HD 6950 2GB
Housed in a Lian Li all aluminum full tower case
Ambient room temp of the rig about 68F or 20C
Furmark default 1080p burn in was used. Both cards OC'd to 840 core 1350 memory with 20% powerboost (using MSI Afterburner) and fans manually set to 100%
So my questions are
My rig
MSI P67A GD65 B3
i7 2600k OC @ 4.2
Seasonic X650 PS
