Summary:
I need to upgrade to new video card and would like 2xDVI + 1xS-Video with HDMI support for the future. What should I do?
Detail:
- I have a 7600GT. 2xDVI + 1xS-Video running 2x LCD monitors + 1x TV via S-video.
- I'd like to replace this card since it's developed some issues.
- I need the new card to support these connectors, optionally with adapters
- Funds are tight and I'm not buying a new TV with HDMI at this time
- It would be nice to get a card that supports HDMI for a future TV upgrade
- Motherboard is Asus P5B with 1xPCIEx16, and lots of PCI slots.
- Corsair 650HX PSU
Option 1:
- Geforce GTX 260 Core 216:
- http://www.newegg.com/Product/Product.aspx?Item=N82E16814130434
Pros:
- Cost $170 for the card
- Supports all connectors needed
- Simple
Cons:
- Does not include HDMI out unless I sacrifice a DVI port.
- Yesterday's technology GTX 260
- Higher heat/power/temp
Option 2:
- Some newer card that doesn't include S-Video e.g. GTS 450 or something. I don't really need suggestions for specific cards right now--just lump all 2xDVI out + 1xHDMI out cards together.
- Example: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130573
* ... or any other similar modern card with 2xDVI + 1xHDMI out.
* The example card is $130.
- Add a PCI card (not express!) with S-Video:
- http://www.newegg.com/Product/Product.aspx?Item=N82E16814130188
Pros:
- Price is still around $200 or a bit less
- Get future proof card with future proof HDMI/HDCP for when I do buy an HDMI-compatible TV
Cons:
- I have no idea how well this approach would work. Two video cards with such discrepant characteristics? I don't want to spend a lot to make this old TV run
Option 3:
- Substitute "Component" with S-Video. My stereo could convert component to S-video so if there are any cards that would do component instead, that works. They all seem to do either both s-video + component, or neither, though.
Option 4:
- Modern card (2xDVI + 1xHDMI)
- Buy a converter for HDMI -> S-Video/Component. These are not cheap--I looked--though I'd be happy to hear more input. It's not a simple wire because of the digital/analog conversion.
I'm leaning toward option 1 but would like some feedback. Would option 2 make more sense?
Thanks
Detail:
- Corsair 650HX PSU
Option 1:
Pros:
- Simple
Cons:
Option 2:
Pros:
Cons:
Option 3:
Option 4:
Thanks
