Shadowssong
- Sep 17, 2009
Hey guys, I originally built my i7 system for just raw computing power and wasn't really planning on gaming, but I have picked up a few games lately (mass effect [fucking amazing game!], crysis and crysis warhead, prototype, grid) and my HD4670 that I have seems to not be able to play everything all that smoothly with the candy cranked up. I play at 1680x1050.
I was looking at the cheaper HD4870's (BTW how is Powercolor's reputation, they have a couple of cheap 4870's), and figured I would just post up and ask what you all suggested.
Also does anyone know anything about this card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150441
I don't see it listed on XFX's website, and google doesn't really turn up many results.
My budget is probably under like 160$ish, as it would probably be a birthday present. I also plan on playing COD6 (but from what I hear it won't be insanely taxing on the system or anything) and also Assassins Creed II when they come out, which gives me a good month or so to choose (I would love to crank everything on AssCreed2, which I hope will be amazing!).
-I also am looking for something that has a low IDLE power, I do a lot of computer work that doesn't use the GPU and I'm always looking to cut my electric bill (utilities in my town are ridiculous!).
-Noise isn't a big problem, my Antec 900 isn't all that quiet, neither is my HyperN520 cpu cooler so if the cooler is a little louder, it is not a deal breaker, when I game I have the sound cranked up anyways!
-I don't need to play Crysis with max AA or anything, in fact, the graphics right now are fairly decent, it just lags pretty hard if anything really difficult to render comes into the screen (lots of smoke, lots of enemies, etc etc). I really probably won't even be playing Crysis that much as I have just beaten it, so I wouldn't factor in the cards performance in crysis when weighing my options.
The rest of the system spec is in the sig.
Thanks a ton, love this forum!
-Shadowssong
-Shadowssong
