I work for a local lawfirm. We have a really cool touchscreen computer/Tv in our large conference room. The computer for this presentation tool is located across the hall (with 15fts ceilings). So the separation between the screen and the computer is about 40ft.
My bosses are now requesting to video conference on this screen, so I need some kind of camera to connect to the computer and give a good clear picture (1080p would be preferred but at least 720p is needed). We would like to have the options open like Skype, GotoMeeting, Google Chat etc...
We need a good camera located in the conference room, preferably above the center of the screen. USB only reaches about 15ft and putting hubs between the computer and the device has been known to cause issues with higher bandwidth devices (like 1080p capable cameras). We already have the conf. room wired with cat 5 and have some usb->Cat5 range extenders already in place. I would consider an ip/wifi security camera but all of them I have seen weren't sending 30-60frames per second. Also it needs to show up in Windows7 as a video camera.
Supposedly a firewire camcorder will show up as a video camera in windows, but firewire has a similar length limit to USB.
I'm not opposed to installing a smaller box closer to the screen (like a netbox) and running the video over network cables. But I dont know what kind of software could use that as an input.
Here's some options I've found in my searching, I'm just really hoping someone has some experience with any of these options or constructing a setup similar to this..
I've previously tested this camera and it makes a great picture
[ame="http://www.amazon.com/Logitech-1080p-Webcam-Pro-C910/dp/B003M2YT96"]Amazon.com: Logitech 1080p Webcam Pro C910: Electronics@@AMEPARAM@@http://ecx.images-amazon.com/images/I/41QsObWW8OL.@@AMEPARAM@@41QsObWW8OL[/ame]
http://www.appbrain.com/app/droidcam-wireless-webcam/com.dev47apps.droidcam
DroidCam can use an android device over wifi as your webcam, seems a good option to me..
http://www.webcamxp.com/home.aspx
This software lists several options for camera hookups (analog, ip) that would allow a longer distance.
http://www.usbfirewire.com/parts/rr-usb2-ext-65ft.html
A usb active extension cable, no idea whether it would work or not.
http://www.ekiga.org/ekiga-softphone-features
Video Codecs Version 3.2
THEORA Video Codec (SIP only)
H.264 Video Codec (SIP only)
H.263 Video Codec (SIP only)
H.263+ Video Codec (SIP only)
H.261 Video Codec (SIP and H323)
MPEG4 Video Codec (SIP only)
These options could be handy for connecting with someone with a standalone solution, like...
http://www.323.tv/products/video-conferencing/conference-room/polycom-hdx-7002-1080
or
http://www.lifesize.com/
Any thoughts on hypothetical solutions or real world experience would be greatly appreciated.
Thanks..
P.s. They make it look so easy in the movies!!
or
Thanks..
