Borgschulze
- Feb 28, 2005
I installed Vista on my laptop recently but had serious sound issues before and after turning up the volume to listen to some music.
I spent quite a while trying to get the Audio to work in Vista... I have a Gateway MX3210 upgraded to 1gb of RAM.
But the problems mainly started after turning the volume up very high and playing some music in Windows Media Player. The audio was fine for about 20 seconds, then it started to crackle and pop.
One thing I did notice is... Vista let the volume go much higher than in Windows XP.
So what I am wondering is,
Did Vista allow my volume to be raised much higher and destroy the speakers in the laptop?
The laptop uses AC'97 audio, I believe it is a Realtek chip, but so many sources give different brands that I can't confirm it without opening the laptop... and I don't want to open it other than the bays to change out the hardware, I assume it'll be a big pain in the ass to do so.
Also, in Windows XP, I have spent quite a bit of time with the volume cranked right up, but now I can't even take the volume up half way without crackling and stuttering.
