Within the last few days, my work laptop has started acting up. It has been running generally slow, but there have been several other, annoying symptoms:
Symptoms:
- Automatic updates have been failing. I tried to update yesterday, the first update finished, but then the 2nd (Windows Powershell) was sitting on the install at about 40% for over an our before I pulled the plug on it.
- General software installation has been slow. I installed SuperAntiSpyware today to start some troubleshooting, and it took about 2-5 full minutes to install. Should take like 30 seconds. When I started the scan its not really doing shit:
Its at 31 minutes now.
- I can't upload files. I tried to put that screenshot up on imageshack, and the upload failed. I then tried to upload it to gmail, and that failed too.
Troubleshooting Steps:
Thus far, I have started up a full antivirus scan (McAfee, required since its a work pc. I use NOD32 at home), and have been attempting the spyware scan. I went to the Conficker Eye Chart, and it says I don't have anything. These sypmtoms have all started around the 1st, however.
Where do I go from here? The antivirus scan is going to take awhile to complete (it is actually running), but the spyware scan seems to be completely borked.
Symptoms:
