I have 2 XFX 6800 Ultra's in an SLI setup (Asus A8N-SLI Deluxe) with an OCZ 520W Powerstream PSU. The rails can handle as follows: +3.3V(28A), +5V(40A), +12V(33A) so the Amps are fine. However it would appear that the voltage on the 12v rail is dropping to aroun 10.8v under load (3dmark05). I can bump it up using the adjustable pots on the rear ofthe PSU but obviously that will overvolt it at default since it rises to about 11.85v when idle.
I have the primary card plugged into the PCI-e connector and the other via PCI-e/double molex addapter with the 2 sheilded molex lines. I have one SATA and one PATA drive, a, NEC DVDRW and a Sony DVDROM. No USB devices yet, and the SIL Raid, Marvell LAN, Serial and parallel ports are diabled. EZ-Plug is connected fine and I have had NO stability problems at all.
Is this drop normal? If it was that bad wouldn't I have stability problems? Some comments would be appreciated.
Thanks in advance
http://service.futuremark.com/compare?3dm05=590789
I'm pretty sure I should be getting more 3dmarks too with SLI...
Thanks in advance
