v1p3r-386-
- Mar 1, 2004
Well I am tired of running my ram at a ratio because I am losing a considerable amount of memory bandiwdth from running my fsb @ 235mhz and my ram @ 188mhz. I have nice corsiar ram, http://www.newegg.com/app/viewProductDesc.asp?description=20-145-450&depa=0 so I should be able to push it pretty far I'm thinking with just some more volts. Currently I have the volts @ "auto" because I can't figure out what the stock voltage for this ram is. I can't seem to find it at newegg or on corsiar's site. But according to cpu-z the model # of each stick is "CMX512-3200C2". So I looked that particular model up on corsiars site (http://www.corsairmemory.com/corsair/products/specs/cmx1024-3200c2.pdf) and it says the stock voltage is 2.75 volts. So how far would it be safe to take the volts up to? They should be able to stand 2.8 or 2.85 I'm assuming if the stock voltage is actually 2.75 volts. Anyways, is the stock voltage 2.75? And is 2.8 or 2.85 safe? Thanks in advance!
