TwiceSliced
- May 1, 2002
I'm a hardware guy before I'm a software guy, but I've been asked to look into some basic VPN functionality for a server at work. It's running Windows SBS 2003 (only has one NIC, but I've set up a loopback connection for the time being), and every client is Windows XP... There's also an old Windows Server 2000 box sitting here that I'll be decommissioning or re-purposing soon.
Anyway, the goal is to have a user log on to their company laptop at a remote location as if they were logging into our domain. Is this possible? I've got it set up such that a remote user can connect to the Windows VPN using the "Log on using dial-up connection" option at the log-in screen, but they can't access any of the domain's resources. I'm guessing I'm either missing something obvious, or the loopback connection is the problem (and I should just install a second NIC).
Any ideas? Suggestions? Or should I just invest in something like this?
Thanks!
Thanks!
